Hey Sloppyjoe!
Make sure you eliminate any possibility of gun components being loose or worn out O-rings, bad liners, clogged diffusers, etc.
Oh yeah, you might want to check for any air drafts.
If the gas analyzer is portable, then take advantage of it...
One more thing that is probably overlooked more than most places and people want to admit is the safety aspect of using a manifold type gas delivery system in a manufacturing plant where alot of argon or CO2 is being used for welding or anything else. What am I getting at?
Last Tuesday the Pittsburgh section of the AWS had a meeting presentation at the BOC Gases National Training Center in Butler, PA. Everyone that attended that meeting was enlightened about how easy it is to become asphyxiated from overexposure to argon and how easy it is to get carbon monoxide poisoning from the use of CO2 if precautions are not taken seriously...
Argon is a very heavy gas compared to CO2, and CO2's byproduct from welding is carbon monoxide!!!
The bottom line is, the HECK with the extra costs of the sensing equipment necessary to monitor and ensure safe levels of O2 or Carbon monoxide in order to avoid poisoning, this needs to be done if they're not already installed and doing their job because, safety must be the first priority especially when you're working with gases that you ca'nt see, smell or can poison you before you can do something about it!!! So please make sure that your O2 levels do NOT go lower than 19% in atmosphere, and make sure you've installed carbon monoxide monitors in your plant.
Otherwise even the people that are'nt even actually performing the welds will drop like flies if unsafe conditions exist inside!!!
Ventilation is'nt enough if the air is'nt being replaced so, do'nt rely on exacuation without replacement and ensuring that the atmosphere has safe levels of EVERY element that makes up the Air we breathe!!!
I kow some people might say: "Well, that only applies to confined spaces." My response to that is: "The atmosphere only has 22% O2 so even a slight drop in percentage can cause an unsafe and potentially tragic situation in any enclosed location that none of us want to answer for in court."
I hope I scared some people enough to rethink their safety plan because, that sure was the intent at the meeting last Tuesday!!!
Good luck with your troubleshooting Sloppyjoe!
SSBN727 Run Silent... Run Deep!!!
Oh yeah, do'nt forget to breathe - clean air that is!!!
