Up Topic Welding Industry / Technical Discussions / Code for Arc and Gas Welding in Building
- - By memerson Date 02-18-2005 23:55
Structural General Notes in construction document drawings often contain the following note: "All welding shall be done by quailified welders and shall conform to the AWS "Code for Arc and Gas Welding in Building Construction", lasted edition". I cannot find this Code reference anywhere on the AWS website or in the catalog. Is this an old Code that maybe was replaced by AWS D1.1 Structural Welding Code - Steel?
Parent - By DGXL (***) Date 02-19-2005 01:21
Talk about being out of date (your drawings, not you), that code was superceeded by the D1.1 Structural Welding Code-Steel. In 1972.
