Short Circuit Metal Transfer (short arc/dip transfer) has the deepest penetration when pulling/dragging the puddle if you keep the wire at the leading edge of the puddle and not in the puddle. Push will give the flattest bead profile and shallow penetration. Spray transfer works best with the push.
