Up Topic Welding Industry / Processes / relilable low temp soldering 24g. 304 st
- - By bzzzzzzzzzz (**) Date 03-08-2005 03:39
What are the fluxes and solders availible for this. zinc chloride and plumbers' solder does not work well enough. I need something that really wets well into the joints. Is my problem in the flux not cutting through the chromium oxides. I need a low temp solder so the sheet doesn't warp a severly when heated.
Parent - By Phil Baskin Date 03-24-2005 16:04
A flux formulated for stainless steel will likely do a better job of oxide removal and attachment to a 300 series stainless steel. The solder can include a tin lead or Lead-Free. Heating and process are key to this application - which is easy to say, but makes a difference for applications.
Does this look like it will help?
http://www.superiorflux.com/pdf/spec/No.71.pdf
