Up Topic American Welding Society Services / Certifications / procedure qualification
- - By John L Date 03-09-2005 18:58
Will qualifing a PQR to weld grade 1018 to A569 qualify me to weld grade 1215 to A569
Parent - - By chall (***) Date 03-10-2005 14:58
What is the welding code you are using?
Parent - - By John L Date 03-10-2005 18:26
We are welding to D1.1.
Parent - By DGXL (***) Date 03-10-2005 21:33
I interprete the D1.1 as "no" to your question. See D1.1:2004, 4.7.3.
Many clients try the argument: "...this material is very similar to that material..." I don't buy it and I'm 99.9% sure AWS does not buy the argument either based upon a letter I have from the former D1.1 chairperson.
Parent - - By MBSims (****) Date 03-11-2005 04:58
Do you have to use D1.1? As I recall, A569 is a sheet steel spec and could be welded under D9.1 or D1.3. What thicknesses are being welded for the A569 and grade 1215?
Parent - By John L Date 03-11-2005 13:38
we are welding 7 gauge A569 to 1215 round ; 1 1/2 dia.
