Both John and Chet offer you sage advice. However, there are some other issues to be addressed. Generally, the first place you should look for code requirements would be the general structural notes of the APPROVED structural drawings(that includes shop drawing as thats all you can inspect to). Most of your basic information such as code, min. weld size, high strength bolted connection type, ect. ect., will be listed in this section. Also look at the section covering "Special Inspections". Theres a few more pearls in there. Since we're talking structures here, chances are that your working to D1.1 and tbl 6.1 would be your acceptence criteria. I have to ask, are you the owners inspector? If so, then the following should be of interest, if not, the following should be of interest. Grab the latest version of the AISC/ASD and go to the Code of Standard Practice, sec 8, Quality Control. Commit 8.1 & 8.5 to memory.
I can only assume that California works under the latest IBC. Section 1704 covers Special Inspections of structural steel, including shop inspections, continuous and periodic inspections of multi pass fillets, fillets exceeding 5/16", full and partial pens and so on. I hope that I havent bored you or told you stuff that you already know. But I thought it would help.
Wayne
That helps a bit.
To start off, I have no knowledge of what the California Building Code says. I assume that other posters we know of from Ca can speak on that.
On D1.1 in general:
Is is not uncommon for smaller jobs to have no welding specs or a general statement to comply with D1.1. That leads one to believe that the welding is unimportant, but you should not forget about product liability and lawsuits.
For jobs with no specs, I would apply D1.1 as the minimum criteria. Often the customer has no welding knowledge and are relying on you to provide the expertise. I would discuss what the customer wants, and tell him/her that you would like to use D1.1 if there is no objection. At least that way you will have used a recognized standard and not your own opinion. I would try to get the approval in writing, possibly by putting a statement on your quotation form.
My initial concern was that no one assume that Table 6.1 is all that matters from D1.1. When we certify that welding is in compliance with D1.1, we are saying that all parts of the code have been addressed unless a portion is N/A. Just using the Table of Contents for example, D1.1 defines limitations to the code, design of welded connections, prequalification of WPS's, qualifications (both non-prequal WPS's and welder qualification testing), fabrication requirements, and inspection.
So to put that in a nutshell, we can't say welding complies with D1.1 if the welder wasn't qualified, the joints were not either per pre-qual or qualified WPS's, base metals were not preapproved or qualified in the WPS, or a number of other concerns.
I may be standing on a soapbox in saying this but to me compliance to a code is all or nothing, and that is what I thought you might have meant in the original post.
Chet Guilford
I have been contracted to do final shop inspection for a small company here in town in the past. I found out a lot about inspecting when there are no specifications and the shop detail drawings don't even list a fillet weld size, they just show an empty symbol. I never knew companies worked off incomplete drawings and info like they do. I made note on my reports of what I found and how I found the welds in accordance to D1.1., quoting the appropriate sections and paragraphs. That is all you can do in that situation. I was hired to perform final inspection for this shop because they did not have a CWI on staff and their contract stated that the steel would be inspected by a CWI before shipping to the jobsite. Anyway we fulfilled the requirements spelled out and they shipped the steel after they made the necessary repairs and it was reinspected and signed off.
The code of Std Practice was mentioned, that is good to file away, I agree with that comment, along with the Fabrication Section 5 in D1.1, as these go hand in hand.
