Nickel Platting probably the best preparation for carbon, low allow or stainless steel for applying a clean very wettable brier coating of 0.0005 inch Ni.
Electroless nickel of 10-12 Phosphorous is suitable for brazing up to temperatures of around 1500°F.
For higher temperatures the best is a watts nickel bath for the plating. I would not use the sulfamate nickel plating processes.
If you are only interested in applying a thin coating of stainless, spray on a very, very thin coating of Nicrobraz 50 (BNi-7) brazing Filler metal and process it in vacuum at 2050°F for 10-30 minutes. If only a small amount of Nicrobraz 50 is applied the coating should be around 0.0003 inch thick.
Bob Peaslee
