Up Topic Welding Industry / Technical Discussions / SS410 to carbon steel welding
- - By asarkar_kolkata (*) Date 03-24-2005 06:25
dear all
can anybody please throw some light on SS410 and CS metal welding by SMAW . can 309Mo be used ? what are the preheat and PWHT requirements ?
regds
Parent - By jerrykroll (**) Date 03-24-2005 12:02
http://aufhauser.net/welding/StainlessAlloys/Stainless.htm
this link may help on filler alloy selection
Parent - By - Date 03-24-2005 12:48
410 is a Martinsitic material that can be joined to carbon steel using a 309Mo. Although the 410 and the carbon steel are not moly bearing steels, the 309Mo can be used, although a straight 309 is a better recommendation. A preheat of approximately 200-250 Deg. F. will allow the 2 different metal to cool down at a more even rate. The 410 can be used in the "as welded" condition. If a PWHT is required, it should be in the range of 1200-1400 Deg. F.
CM
