Up Topic Welding Industry / General Welding Discussion / welding stainless steel tanks
- - By - Date 10-31-2000 14:43
I have a job of making a couple s.s. water holding tanks. These are 15ft high x 10ft in dia. & made of 304L s.s. x 14ga. in thickness on the side & top & 11ga. on the bottom. These are made in three 5ft sections. We have made one of these before and the problem encountered is that at the welded seams of each section (not the verticle ones , they are overlapped 3") the sides draw inward. These are welded inside and out, we used Tig , Mig & stick. Any ideas on how we could weld these differently so as to have nice flat sides?
thanks bruce.
Parent - By G.S.Crisi (****) Date 11-08-2000 00:59
The problem arises because the plate is too thin. It's possible to correct it and I'll suggest you two ways.
1) The easier way.
Gouge the circumferential welds by the same side where the draw is. If it's inward, as you say, then it means that you'll have to gouge the welds from the inside of the tank. Attention though!!! If you use a carbon electrode for gouging, you'll have to remove thoroughly the discolorations produced by gouging, because that discoloration is a carbon rich region, where the corrosion resistance will be sharply reduced.
If you use a grinding disk for gouging or for cleaning the discolorations, attention!!! In this case, the disk must not be made of silicon carbide (carborundum) for the same reason explained above. The disk should be made of alumina. Once the welds are gouged, weld them by the same side where the gouging is. The warpage should disappear.
If not, you'll have to go to the second (and more difficult) method. This I'll explain you if, after you've tried the first one, you've got poor results.
Parent - - By Weldmedic (*) Date 11-12-2000 06:31
Bruce,
I believe the answer to your problem is modifying your welding plan.
Since the section thicknesses are fairly light, I would fit up the welds with a root gap of 1/8" to 3/16". I will make an assumption that your are welding on rollers so if not, let me know. Purchase ceramic backing material(I like the Refract-e-back by alloy rods).These tiles are 1" square and come either flat or with a groove to mold the weld bead opposite side. They come in strips with a foil tape and adhesive to hold them in place. Assure that the surface to mount them is clean and free of any dirt or oil. Apply the backing centered on the weld fitup on the outside of the tank and weld from the inside. Once complete remove and clean the out side and touch up any questionable areas. Make sure this complies with your Welding Program Procedures. I am confident that this will minimize the problems you are having. I would run a few samples with this technique to get a good feel for it as you may wish to adjust the root gap to suit your personal style.
I have found that the extra cost (about 2$ a foot) is more than offset by the savings in labor and the quality of the finished product. Good luck with your project.
Steve Dodd
Parent - - By elisagrace Date 09-28-2016 12:18
It can be  with the pulsed MIG process, "if using weld automation", increase the stainless thin gage weld speeds, and also provide superior weld surface, (slightly more fluid). With the pulsed MIG gage welds, you will likely be using an 0.045 wire, for the gas mix, consider using the two part gas mix that I developed for stainless, it's argon 2% CO2, (see my MIG gas section). The pulsed MIG benefits are attained for stainless or duplex applications in the range of 14 gage to 3/16 thick . http://www.greatbasinindustrial.com/maintenance-repairs-and-alterations
Parent - - By fschweighardt (***) Date 09-28-2016 12:22
16 years, is this a record for resurrection?
Parent - By 522029 (***) Date 09-28-2016 13:18
Sometimes, you just have to laugh!!
Griff
Parent - By Lawrence (*****) Date 09-28-2016 13:55
You developed 98/2  !?!?!?!?!?
That is very impressive
