In your Yellow Pages.
JTMcC.
By -
Date 03-31-2005 23:02
Excellent answer. All he has to do is look under "steel" in the yellow pages. Mmmmmm... this was a toughie.
CM
I assume that the problem is that you only want a piece or two and the steel suppliers have high delivery charges on small orders. Often the steel companies will sell small quantities if you go there. Some welder/fabricators will sell at retail or would add your piece to their order for you. You will then have to wait until the order gets large enough to trigger delivery.
Bill
See if there is a metal supermarket in your area
http://www.metalsupermarkets.com/
No minimum charge.
Good resource for small quantities of any metal.
What wall thickness and lengths are you looking for?
John Wright
By -
Date 04-01-2005 18:08
Further to Bill Vanderhoof's reply, you may want to try LeJeune Steel ( a fabricator) or Ryerson ( a steel supplier), both in the Twin Cities area.
Mankenberg
