Steve is correct, the direct brazing of aluminum to copper is not recommended as it results in intermetallic, which compromise the joint strength.
If the copper is plated with 0.0127 to 0.025 mm of nickel, the aluminum can be brazed to the plated copper using AWS BAlSi-4 brazing filler metal (Al-11-13% Si) using any of the standard aluminum brazing methods. Bob Peaslee
