For thin metal welding, such as duct work I use Everdure 254 (Miller Product). It is great for welding galvanized material. It is used with tig welding, you need to direct the arc on the rod. It flows on like brazing (very effective and fast). Depending where you are from, you may have to get a similiar product form a different company.
Good-luck.
