Dear friends,
Double-walled thin Aluminum tube, no clearance between walls ( plastic deformation), circular welds at both ends all around the edges ( edge weld without filler). Wall thickness = 2.4 mm, mean diameter 29 mm.
TIG DCEN, Trimix electrode 1.6 mm , 60o, gap 0.8mm linear speed about 4 mm/sec, current 45 A. Pure helium 15-20 cfm, 6mm alumina nozzle.
Two massive copper heat sinks, external and internal, placed 2.4 mm bellow edge.
Trouble : important black soot deposit mainly on the heat sink, about 10 mm wide, but also on the weld bead itself. Soot may be easily removed with a soft brush. Trouble of the trouble is that soot is present on that part of the weld which has to be overlapped for welding completion
How can I get rid of the soot?
Thanks
Calin Truta
trutacs@gmail.com
Hello Truta, just looking at your post, if I understand it correctly, you've got a double-walled aluminum tube that you are welding the end together, I'm assuming, to fuse the inner and outer tubes together at their ends before you possibly weld this to something else which requires additional welding over the ends that you have previously welded. If this is the case, it sounds to me as if you may have some contamination issues from the manufacturing process related to the double-walled tubing itself. Most likely during the manufacturing process of the tube they are using some sort of metalworking fluids to aid in the production of this material. Possibly a film of the fluid is present between the inner and outer tubes and is boiling out of the joint as the welding is taking place and causing contamination issues. I can't fully picture the situation you are describing, if possible try to clarify a little better. If you are running into contamination due to the situation I have described, it could be very difficult to alleviate this problem because of the tolerances between the inner and outer tube walls. It might require washing these parts in a very hot bath of some sort of cleaner or solvent that would break down this metalworking fluid and then allow it to dry without a residue. After re-reading your post I did notice you are using DCEN current for this. Is there a particular reason for this particular choice? You may have noticed from some of the other posted responses on this thread that the cosmetics from this particular process are somewhat dirty. Hope this will help some. Regards, aevald
Some more details :
Indeed, the ends of the two tubes are to be welded together, but no other weld follows. My concern is for the final stage of the weld, where I have to overlap the first millimeters of the weld, in order to complete a circle weld of 360 deg + 30 deg overlap
The soot starts forming just immediately after welding starts, and its trace is nice and uniform on the heat sinks
The tubes are thoroughly cleaned prior welding in acid mixture, washed and dried in vacuum
I use DCEN with HF start sparkle because I have a suitable machine for this, unfortunately without AC ( Weldlogic AWS 150).
Could it be the quality of the heat sink material?
There are articles on the web, stating that "helium arc generates black soot" with no explanation and with no prophylaxis
Thanks for your patience
Calin Truta
It sounds like you have a contamination problem to start with. I would try to weld a set without using an acid mixture cleaning method. If there is anyway possible you need to just degrease them with some acetone or isopropyl alcohol and scrape the area you will be welding or using some scotchbrite to clean the area. When you use some acid mixtures you will have a risk of the material holding some of the mixture and when heat is applied then you will have some contamination in your weld puddle.
You also mentioned that you are not using a filler. I would watch for cracks if this is the case. When you weld autogenous there is a risk of cracking depending on the type of material you are using.
What type of aluminum are you trying to weld?
If this does not help please email me again and I will see if I cannot find some other suggestions for you.
Gina
If You cut an assembled tube apart after cleaning but before welding how cleen are the tube surfaces where they were in contact? Could there be contaminants or oxides trapped in the joint?
