Up Topic Welders and Inspectors / Education & Training / shrinkage
- - By PAYAM DADJOO Date 04-28-2005 05:17
I search about " how can we reduce shrinkage during welding?"
Parent - By mksqc (**) Date 04-28-2005 15:43
YOU NEED TO EXPLAIN MORE ABOUT WHAT YOUR WELDING. BUT IN GENERAL A PROPPER WELD SEQUENCE WOULD HELP.
Parent - - By - Date 04-28-2005 18:27
Proper control of welding variables will help eliminate conditions that promote shrinkage and distortion. These include fillet weld size and length, including tack welds; using high speed welding; using a lower heat input; using intemmitttent weld beads; using the backstep technique; and balancing the heat in and about the neutral axis of the butt-weld. Restraint of the piece being welded will also help eliminate the shrinkage and distortion, but care must be taken restraining the weldment since it can cause residual stress on the molten weld pool which can possible lead to solifidication cracking. Residual stresses in the weld joints are going to be unavoidable, though. Regardless of your weld technique, high tensile stresses will occur in the weld area.
Stresses, shrinkage, and distortion occur automatically, but to what degree depends primarily on the thickness of the base metal and the weld process you choose. May I suggest you do a "mock-up" of the piece to be welded to determine which process, technique and heat input that best suits your needs.
Chuck
Parent - - By swnorris (****) Date 04-28-2005 21:54
Excellent points by Chuck. Shrinkage cannot be prevented, but it can be controlled. There are methods used in both the design and in the shop to overcome the effects of the heating and cooling cycles of the materials welded. Briefly, here are a few (Some previously mentioned by Chuck):
1. Do not overweld. The more metal placed in a joint, the greater the shrinkage forces.
2. Use intermittent welding rather than continuous welding when possible.
3. Use as few weld passes as possible. Fewer passes with large electrodes are preferable to a greater number of passes with small electrodes.
4. Place welds near the neutral axis. This provides smaller leverage for the shrinkage forces to pull the materials out of alignment.
5. Balance the welds around the neutral axis. This offsets one shrinkage force with another.
6. Use the backstep welding technique.
7. Anticipate shrinkage forces by placing parts out of position before welding. The required amount of preset for shrinkage to pull the parts into alignment can be determined with a few trial welds.
8. Plan the welding sequence. A well planned welding sequence involves placing weld metal at different points within the assembly so that as the assembly shrinks in one place, it counteracts the shrinkage forces of welds already made.
9. Peening is one way to remove shrinkage forces of a weld bead as it cools, but this method must be used with caution. Engineer approval should be obtained prior to peening.
10. Minimize welding time. It is desirable to finish a weld quickly, before a large volume of surrounding metal heats up and expands. Excessive heat expands the base metals more than necessary.
The welding process used, the type and size of electrode, welding current, and travel speed all affect the degree of shrinkage in welds.
Parent - By - Date 04-28-2005 22:32
Mr. Norris,
Excellent additional points. Thank you. This should cover most, or all, of the scenarios. Thanks again.
Chuck
