Up Topic Welding Industry / General Welding Discussion / Welder recommendation?
- - By Murray Date 04-29-2005 04:54
I am interested in purchasing a welder and plasma cutter to do small run fabrication with various metals including: cold rolled steel, stainless steel and aluminum. I need a welder that is very versatile as I am on a tight budget. I am seriously looking at the miller XMT Multi Process Welders and their plasma cutters. Any comments or suggestions would be greatly appreciated!
Murray
Parent - By pjseaman (**) Date 04-30-2005 01:06
The XMT is an awesome machine but it wont do AC Tig for aluminum. I believe the XMT is a great machine, I've used it on stick only but the other machines in the same catagory all work very well. I've used the ALT in DC tig and mig as have I used the invision in stick and mig and all perform well. Solid equipment and a good choice.
Good luck, with the venture.
pjseaman
