Need some info on MMCW. Have any of you pros out there had any experience with welding MMCW on pipe. What are your results? Have you had good results with this wire when welding on pipe? Do you use it for the first pass or just on backing? I have been doing some reading regarding MMCW on the fabricator website, they give it high marks.
Would like some feed back also on the following:
Voltage; Wire feed speed; type of gas & CFH flow; type of wire.
Any info would be greatly appreciated.
Thanks! welder5354
