Up Topic Welding Industry / Technical Discussions / WELDING STEEL DIN 1.8550 34CrAlNi7
- - By GIOVANILOPES (*) Date 05-03-2005 01:35
Hi Sirs,
I need to weld the steel EN 1.8850 34CrAlNi 7.
Can someone please suggest a reliable supplier for filler rod or stick ?
Thanks,
G. Lopes
Parent - - By G.S.Crisi (****) Date 05-06-2005 12:46
Here in Brazil there are ESAB, Thyssen Boehler, Eutectic and Kestra. The latter is a specialist in stainless steel.
None of them satisfy your needs?
Portuguese translation
Aqui no Brasil tem a ESAB, Thyssen Boehler, Eutectic e Kestra. Esta última é especialista em aco inox.
Nenhuma delas atende sua necessidade?
Parent - By GIOVANILOPES (*) Date 05-06-2005 14:51
Mr. Grisi
Already I welded this material to some time. One is about a steel for nitrogen hardening. We made an union of a steel shaft of 5000 mm.
Greetings and grateful for the return.
