Dear Mr. Agarwal,
As I told you when I answered your question posted on September 19 and titled "Cold drawn erw pipes", first thing you've got to do is to read the standard the pipe is made to, in this case BS 3059. Does the standard specify which NDT must be made? If so, it's not up to you to choose the kind of test, but you should follow what the standard says. However, if the standard leaves the option to the manufacturer, but only in that case, you can choose the method.
ERW pipes use to have internal fins. If those are unacceptable to you, then the only method I know to get rid of them is by cold drawing.
