By -
Date 11-05-2000 15:30
My shop routinely welds chrome-moly pipe using a GMAW short arc root, and GMAW pulse spray fill and cap. The filler wire needs to be matched to the base metal. For example, for 2-1/4 Cr - 1 Mo, the wire is ER90S-B3. The gas for the short arc is 75% Argon/25% CO2. For the pulse spray portion, the gas is 92% Ar/8% CO2. I'm not familiar with the NHRA specs that you are refering to, but you can get excellent results using GMAW on chrome-moly.
