Up Topic Welding Industry / Technical Discussions / Stud Welding Question
- - By ftorre (*) Date 05-18-2005 18:33
I was wondering if anyone could help me out with some information concerning stud welding. Is it allowed to weld two studs(one on top of the other) to achieve a desired stud length. For exampl: a 12" stud is required, can to 6" studs be welded together to achieve the required 12"? I cannot find anything in D1.1 that would not allow this. Any info would be greatly appreciated. Thanks.
Parent - - By QCCWI (***) Date 05-18-2005 18:45
Yes you can stack studs if the engineer of record approves it.I have never been told I could not stack studs but it is the EOR decision to make. He/She does have the option to say no.
Parent - By swnorris (****) Date 05-18-2005 21:47
I agree with QCCWI. We call it piggybacking, and have had it approved in a few emergency situations over the years.
Parent - By ftorre (*) Date 05-18-2005 22:44
Thank you for the feedback, it's greatly appreciated.
Parent - By jwright650 (*****) Date 05-19-2005 12:47
We have done that also, perform the usual testing in your shop per Section 7 of D1.1 and Ok it with the EOR, and you should be good to go.
John Wright
