You're not the only one, Charles.
Back in my days of erector engineer, I'd been in charge of the erection of the piping of two power plants, one within an oil refinery owned by Petrobras (the Brazilian state oil company), and the other one within a pulp and paper mill owned by a Japanese company.
In the first case, the piping was designed to B31.3. Petrobras' argument was that, although the piping belonged to a power plant, it was located within an oil refinery, and so B31.3 was the applicable Code.
In the second case, the piping was designed to B31.1. The Japanesemen's argument was that, although the piping was located within a paper mill, it belonged to a power plant, and so B31.1 was the applicable code.
Well, this happened some 15 years ago and both piping systems are still in service; none of them blew up, which indicates that both codes are good.
