The soldering of aluminum differs from the soldering of most other metals in several ways. The most important concern is the oxide that forms rapidly on aluminum. In most cases, this requires the use of active soldering fluxes that are specifically designed for aluminum. Non corrosive fluxes are not suitable. A second difference is that special techniques are required to obtain solder flow into certain types of joints. A third important difference is that the corrosion resistance of soldered aluminum joints is more dependent upon the composition of the solder than for similar joints in copper, brass, or steel. Alloying elements influence the solderability of aluminum. Commonly soldered aluminum alloys are 1060, 1100, 3003, 5005, 6061 and 7072. Readily soldered aluminum alloys contain no more than 1% magnesium or 5% silicon. Alloys containing greater amounts of these elements have poor flux wetting characteristics and may be rapidly attacked intergranularly by the solder. The commercial solders for aluminum can be classified into low (300-500 degrees melting range) , intermediate (500-700), and high (700-800) temperature groups.
