I really don't know how to test it "properly" but it has pressure to the solonoid (no obstructions in the lines and gas in the tank), it has voltage to the solonoid when the trigger is depressed (42 volts) and no obstructions from the solonoid to the gun. There is very little ohms in the solonoid when tested. I finally found a phone # on the welder and tried to call it and was transfered 3 times but finally got a part # and got one ordered, kind of expensive ($50.86) in my opinion but hopefully it will get things working again, without all the splatter.
Thanks for the reply, I found this site by chance and seems to have some very info on the board and will keep this site in Bookmarks for later use.
Speed Safely,
Randy
*edit* by the way the solonoid did have 120 volts stamped on the base of it, just don't know why it only has 42 going to it?
