Hello,
so I have some experience with stick welding and a little experience with actylene torches.
I have two thin pieces of spring steel I need to connect together. The pieces are part of a puppet that gets a lot of usage. A welder friend told me I had to braze or solder the spring steel with a torch since it couldn't be welded. Is this true? If so, what is the proper way to braze or solder the pieces?
I have tried to wrap the joit with thin copper wire, coat the joint in flux paste, and then applied the torch till the spring steel turned reddish orange. When I applied the solder, it pools up but doesn't seem to penatrate the joint. Also, if I hold the torch on the joint too long, the copper wire melts. I've retried this method without the copper wire, and then without the flux to no avail.
So what am I doing wrong?
