Up Topic Welding Industry / Technical Discussions / Manganese steel welding
- - By nanda Date 06-28-2005 11:56
I would like to know what kind of process/filler rod suitable for welding of Manganese steel (carbon 1.15%, Si 0.4%, Mn 13%) to Manganese steel. My objective is to increase productivity either by GMAW OR FCAW.
Currently we are using SMAW and productivity is low (plus operator discomfort).
Sometimes we have observed centreline crack on the weld. Is it due to excessive current OR electrode quality or material defect..? Any inputs to avoid rework is welcome.
Parent - By PhilThomas (**) Date 06-28-2005 17:51
You can use Stoody Nicromang wire:
http://www.thermadyne.com/stoody/literature/pdfs/Mnw002.pdf
HTH,
Parent - By pgeweldor (*) Date 07-03-2005 01:24
You can also use Certanium 706. Good luck.
