While carrying out welding procdure qualification of ASME 335 P91(TIG+SMAW) for main steam pipe in power plant, is it need to take Charpy impact samples at the root of the weldment to include the TIG weld metal (ususally 2 pass, 6mm)? or just take samples at the outer side of the joints?
in China only samples at SMAW weld metal will be taken out, would you please tell me the situation in USA or Europe?
when PWHT at 760 degree from the outer side, the real temperature at the inner root will be 740 degree or lower due to the heat loss, how to garantee the impact toughness of the root weld metals at so low PWHT temperature? thank you very in advance!
