Up Topic Welding Industry / Technical Discussions / about plazma arc gouge
- By jiweiming (**) Date 07-16-2005 08:01
As you know,when we manufacture duplex stainless steel such as ASTM A240 S31803(2205),we are not allowed to use carbon arc gouge,so what is your gouge method? mechanical grinding is the exception.It is said plazma arc gouge does. Is it?If so,where i can get such an equipment?
Many thanks.
