Up Topic Welding Industry / Technical Discussions / welding 416 stainless steel
- - By jer (**) Date 07-17-2005 02:54
I have a part that is made from 416 stainless steel. I was wondering if I could use 420 stainless rod for it ? or can 309 be used ?
Parent - By - Date 07-17-2005 12:06
Type 416 Martensitic stainless steel is a free-machining grade that is weldable providing the process, or filler metal, does not supply hydrogen that can react with the sulfur or selenium in the base metal to produce porosity. Due to the amount of sulfur that enters the weld due to dilution, the filler metal selection should provide weld metal that can tolerate these elements without hot cracking. An E312 series stainless steel is one of the better choices. A nickel-alloy filler metal cannot be used due to the formation of low melting nickel eutectics, which cause hot cracking. Personally, I would recommend the 312 series over the 420 or the 309.
Chuck
