mernst,
Although I don't think it applies here, there are conditions that fillet welds should not be continuous. See 2.8.3.5 and Figure 2.8 in D1.1. The main reason for this is to eliminate the potential for notching. Also, I look through the design drawings and get familiar with a job before we start detailing and fabrication. Once I see the fabrication drawings, I sometimes see "all around" welded joints where they couldn't possibly be needed. I go back and look at the design drawings, and there are no welding symbols shown for some of these. I have found that sometimes the detailer just shows all around welds just so he doesn't have to do any calculations. Sometimes the designer does the same thing. Are any of you seeing anything similar to this?
