Greg,
I respectfully disagree. You posted "ASTM A108 is the requirement for the stud material itself, not the approved base metal". Does that mean that if I wanted to weld any other metal that is not shown in Table 3.1 to a prequalified base metal, that it would be prequalified or ok? I agree that ASTM A 108 is the material specification for the stud. I agree that fillet welds are prequalified, and I agree with using a prequalified FCAW, GMAW, or SMAW process as indicated in 7.5.5, but where is it indicated that ASTM A 108 is a prequalified material to use a prequalified process to weld to it? It is not found in Table 3.1, and I didn't see the " Note: Approved steels: for studs, see 7.2.6: for base metals, see Table 3.1 (Groups I and II)" that you referred to. Am I looking in the wrong place? Another thought: Just because there are approved steels for studs doesn't mean they're prequalified, just like GMAW-S is an approved process but it is not prequalified. After further research, here's another twist which seems to contradict both of us: Look at C7.5.5. It states in the last paragraph that "Studs welded by the use of automatically timed welding equipment or fillet welded by SMAW are considered to have been welded by a prequalified WPS. The paragraph title, "C7.5.5 FCAW, GMAW, SMAW Fillet Weld Option" indicates it's ok to use either of the three, but as you read further it states that only SMAW is prequalified.
Scott,
AWS D1.1-2004,page 253
7.2.6 STUD MATERIAL Studs shall be made from cold drawn bar stock conforming to the requirements of ASTM A108.
7.1 Scope
Note: Approved steels; for studs, see 7.2.6, for base metals see Table 3.1 (Group I and II)
So my thoughts are, you can only use ASTM A 108 for the stud itself, and you can only apply said stud material to a base metal that appears in either Group I or II material. As for qualification testing:
7.5.5 .... may be welded using prequalified FCAW, GMAW, or SMAW processes, provided the following requirements are met:
It seems one thing missing here is Ken hasn't told us what his position is with regard to these questions. Not that the answers will change, but it helps knowing when one responds whether one is responding to an engineer, quality inspector or craftperson.
Greg,
Ok. I see the note under 7.1, but with all due respect, that still doesn't convince me. 7.1 Scope refers the reader to "7.2.6 Stud Material", which is approved steels for studs. The note also says "for base metals, see Table 3.1 (Groups 1 & 2)", which is a list of prequalified base metals. However, when you go to the table, the approved stud steel is not listed, which indicates to me that it is not prequalified, but it has been approved to use. I have always thought that when it comes to welding two metals together, you are prequalified in D1.1 as long as those two metals are both listed in Table 3.1. If one is and one isn't, and you want to weld them together in accordance with D1.1, you must qualifiy a procedure to do so. Did you take a look at C7.5.5, particularly the last paragraph?
