Metal to earth, All position, Any shielding gas, up to 12" 45 pound spool,
Thanks
Have you looked into purchasing a copy of the AWS Specification for Welding Earthmoving and Construction Equipment D14.3? This guide provides the standards needed to produce the structural welds used in the manufacture of crawlers, tractors, loaders, power shovels, backhoes and other self-propelled machinery, and places a heavy emphasis on workmanship and welder qualification. In addition, the specification also provides illustrations of prequalified welded joints for a variety of welding procedures.
If you truly need all position capability (specifically, vertical and overhead), then look at Stoody 965AP-G
http://www.thermadyne.com/stoody/literature/pdfs/Crcw002.pdf
but if you can get by with welding flat and horizontal, then you could use 121-G or 101HC-G:
http://www.thermadyne.com/stoody/literature/pdfs/Crcw004.pdf
http://www.thermadyne.com/stoody/literature/pdfs/Crcw009.pdf
All are tried and true products.
For what is is worth I've used the McKay Tube-Alloy 255 gas shielded flux cored wire in the past with good results (.045 dia.). Expect it to cross check crack though. Below is a link to the 255 brochure and links to other self shielded and gas shielded McKay hard surface wires.
http://www.hobartbrothers.com/pdf/TubeAlloy255_G.pdf
http://www.hobartbrothers.com/results.asp?brands=4&category=10
http://www.hobartbrothers.com/results.asp?brands=4&category=9
