Thanks for Reply. No The transducer are normal but we are maintaining the gap around 0.5 mm in between the pipe surface and probe surface also we are using hard face material for probe construction.
Another question is the production rate is fast and For continuous online testing conservation of the couplant is more i.e 1 liters in 1 minute.
Is the silicone greases or Synthetic motor oil cost effective solution?
Are there any possibilities that these couplant will changed the weld strength characteristics?
