Hi Kipmank!
I've never seen GTAW in the short circuit, globular or spray transfer mode... Then again, I have'nt seen enough in my lifetime to claim that I have... Anywho, my original question referred to Gas Tungsten Arc Welding as opposed to Gas Metal Arc Welding.
I apologize for not having immediate access to ASME Section IX. The problem is that I do not have immediate access to QW-250 through QW-280 or Article IV, Welding Data.
So, would it become a requirement to qualify a new WPS if one decides that they are going to add pulsing to the original non-pulsing GTAW process they had listed in the original WPS, provided that nothing else has been changed in the procedure they are welding to?
The reason I'm seeking clarification on this is because, I was previously informed that pulsing with GTAW was considered a supplementary essential variable, and had to be listed in the WPS. If it is'nt listed in the original WPS, then a new WPS has to be requalified if pulsing is to be included in the production process.
Am I incorrect? Thanks in advance.
SSBN727
Run Silent... Run Deep!!!
