Up Topic Welding Industry / Technical Discussions / Hand held SAW
- - By sbruno (*) Date 08-12-2005 20:08
Do I need to recertify a SAW PQR if I change from Automatic to semi-automatic?
Parent - By mraschis (*) Date 08-12-2005 20:23
Yes , For SAW semiautomatic you need a welder qualification test, remember that SAW Machine qualify a welding OPERATOR,. If you are working D1.5 see Part B
Parent - - By GRoberts (***) Date 08-12-2005 23:00
For ASME IX, you would not have to requalify your WPS, as a change from automatic to manual is a non-essential variable.
Parent - By sbruno (*) Date 08-15-2005 14:24
Thanks all, Part B explained what needs to happen. In case no one has ever said it, this forum is by far the best. Almost all the people that partcipate are professionals and help with questions that peolple like myself are sometimes a little confused.Thank you again.
