Up Topic Welding Industry / Technical Discussions / Tell tale hole for Trunnion support.
- By JCaprarulo (**) Date 08-21-2005 22:46
My question is about that type of pipe support, fited and welded in elbows from piping.
I canĀ“t found where is specified about "tell tale hole" not screwed and located in the base of support pipe to be made in order to detect any leak from supported pipe.
