John; the exact same stuff! It buffs off very easy though (when fresh) and the enamel does work well! A funny (not really) story of when I was a young pup of an inspector, my very first acid etch on my own (inside the shop) and with BRAND NEW linoleum in the test area, I couldn't find anything to put the mix in so finally found an old tin can! Oh, my goodness, you never saw someone run so fast! Grabbed the can with a pair of old plyers and flung it off the loading dock! A good lesson; never mix acid into anything but glass or plastic containers! And, of course, never mix water into acid!!!!
