Up Topic Welding Industry / Technical Discussions / Vertical Upward and Vertical Downward
- - By assaduet Date 08-26-2005 16:26
When vertical upward and when vertical downward technique is used ? what are their advantages and disadvantages ?
Also plz tell me the application of vertical downward technique ? and why
regards
Assad
Parent - By chillin Date 08-30-2005 05:03
v-down is faster and you can fill bigger spaces say for instance your gap isn't just peachy so you run some downs to close your gap or butter the edges.
V-up is much stronger and a hell of alot harder, which is why I prefer v-up unless I'm absoleutely certain I can get Complete Joint penetration with my downhill welds. Works good for thin steel but on anything that counts V-up.
