Up Topic Welding Industry / General Welding Discussion / 110-120V AC/DC Inverter Tig/Stick?
- - By jyardblacksmith Date 09-04-2005 20:24
Is there a manufacturer out there that makes an inverter Tig/Stick welder that will operate in AC and DC from a 110-120VAC outlet?
Been needing a small Tig that I can plug in the wall anywhere and weld steels as well as aluminum, but I can't find AC/DC Tig in any outlet voltage less than 208-240.
Parent - - By sundown Date 09-05-2005 15:41
Miller Dynasty 200, either the SD or the DX is AC/DC, 120V-460V, single or 3 phase with autoline plug and play. A bit pricey but it will do what you want.
Parent - - By jyardblacksmith Date 09-05-2005 22:12
I didn't even know Miller made that, and I just got their new cataloge.
Thanks.
If anyone else comes across another make, drop me a reply.
Parent - By StretchNM Date 09-07-2005 22:20
Lincoln Invertec V-205T
