Up Topic Welding Industry / Technical Discussions / Crossing the fillet weld on the ButtWeld
- By khodabandeh (**) Date 09-05-2005 13:05
Dear Sir,
I would like to know that,if it is crossing the fillet weld of saddle component from the groove weld that is make a probleme or not?in power plant project one butt weld joint put in the saddle and crosse the fillet weld on the groove weld I want to know the refrence of standard code of ASME B31.1, ASME B31.3 if that is not permitted.
