Up Topic Welding Industry / Technical Discussions / ASME Sec. IX code case for U.T.
- - By Jim Hughes (***) Date 09-07-2005 14:21
Does anyone know the code case for allowing U.T of a welder test. I know it was in the ASME Sec. IX 2000 addenda but I can't find it. If someone could give me the case number I would appreciate it.
Thanks
Jim
Parent - By jon20013 (*****) Date 09-07-2005 14:48
Jim; check out the following link, I believe you will find it there! Good luck!
http://cstools.asme.org/csconnect/CommitteePages.cfm?Committee=N20120000&ProposalsSearch=yes
Parent - - By dlmann (**) Date 09-07-2005 16:31
Jim: This link will give enough information to get started. However you will not find welder quailficatiuon by UT in Section IX. It has been reaffirmed in the 2004 edition and is still current. You will need ASME code case 2326.
http://www.sperkoengineering.com/html/articles/2000%20Addenda.pdf
Regards, Donnie Mann
Parent - - By jon20013 (*****) Date 09-07-2005 16:56
Mr. Sperko has some very excellent information on that link, doesn't he Donnie? Sorry Jim, I should have sent ya that one too!
Parent - By Jim Hughes (***) Date 09-07-2005 18:41
Thanks everyone. Your responses were a big help.
Jim
