I think before trying to re educate the engineer, the first place you should go is to the project specs and see what was called out for filler metal requirements. If there are CVN requirements, then you have both legs to stand on. SWNORRIS is correct in that the 71-11 wires have no CVN values. The 71-8s' all have values starting at 20 ftlb @-20 and offer superb low hydrogen characteristics. Other than that, they both operate under approximately the same perameters, with the exception that the -11 cannot be used on materials thicker than 1/2". If the EOR doesn't have a problem with it, then you shouldn't either. Just have the welders fill out the bevels (or grind them out if it comes to that)and write it all up.
