If you are asking about the core wire for AWS A5.1 or A5.5 carbon steel or low alloy steel covered electrodes, the core wire is typically a AISI 1005 or 1008 mild steel. The elements present would be as follows:
AISI 1005
C Max 0.06
Fe 99.5 - 100
Mn Max 0.35
P Max 0.04
S Max 0.05
AISI 1008
C Max 0.1
Fe 99.31 - 99.7
Mn 0.3 - 0.5
P Max 0.04
S Max 0.05
You should note that, other than the Mn, there are no deoxidizing elements present that would typically be found in GTAW filler metals, such as Si, Al, Ti or Zr. The same core wire is used for CrMo covered electrodes also.
