Up Topic Welding Industry / Inspection & Qualification / Groove weld on the Saddle
- By khodabandeh (**) Date 09-30-2005 06:21
Dear Sir,
I would like to know that,if it is crossing the fillet weld of saddle component from the groove weld that is make a probleme or not?in power plant project one butt weld joint put in the saddle and crosse the fillet weld on the groove weld I want to know the refrence of standard code of ASME B31.1, ASME B31.3 if that is not permitted.
