Hi Donnie,
First of all, let's imagine those little boxes in the literture are drawn in the sand and you are standing over them looking down at them. The first box has the arrow outside the box, pointing up, to indicate the ability to use the 2.0mm (5/64"), 2.50mm (3/32"), and 3.25mm (1//8") in the vertical up progression. It also shows these diameters can be used in the push progression (arrow up), pull progression (arrow down), horizontal progression (arrow to the right), and a 45 deg. angle up ( arrow in the 45 deg ). I will say that it is easier to weld vertical up with the 5/64" and the 3/32" electrode, but the 1/8" is certainly possible. When welding uphill with these rods, you must use a "triangle" type welding technique, not a weave type technique. As the other 2 boxes indicate, none of those rods are designed to weld vertical up.
Using the short arc length is the way to go. Actually, the best way is to have the rod in contact with the metal at all times. Instead of a short arc, actually drag the rod on the metal.
If you have any questions, leave a phone number and I will call you and explain about the triangle type welding technique and try to answer any other questions..
Chuck
