I have comiserated for some time the most proper interpretation of Table 4.9, used in conjunction with Table 4.10., as follows:
If a welder qualifies with a plate groove, Table 4.9 indicates qualification is included for pipe fillets, (as long as dihedral angle is not less than 30d).
Nowhere does it address diameter restriction/allowance. Note 3 (24" restriction) would appear to apply to groove welds only.
Can anyone help clarify whether the code simply does not specifically address fillet weld DIAMETER, and the welder is qualified for all diameter fillet welds, or am I missing something ? ASME IX is pretty clear on this matter (QW-452.6)
Elsewhere in Table 4.10, (production T-Y-K connnection fillet welds) there is a provision to test a fillet weld of dia. "D" to qualify fillet welding "D" and greater. I will generally have a welder do a pipe fillet weld test on the smallest dia. he may encounter as well as the groove plate to CMA.
