$800
This is a used Millermatic Mig Welder in perfect working condition.
36"x18"x27"/165 lbs. MIG (GMAW)/Flux Cored (FCAW)
Comes with everything needed to get started.
Miller designed the Millermatic 185 MIG welding package especially for the racing industry. With 30 to 185 amps of output power, it has the capability to weld steel from 18 gauge to 3/8 in. and aluminum from 16 gauge to 3/8 in. in diameter. In addition, this welding unit provides excellent short-arc performance, as well as the versatility to weld everything from thin gauge materials like car door skins to thick materials like frame rails
If you want to weld material from 22 gauge up to 3/8 in (9.5 mm), this is the machine for you. It's easy to set up, offers a wide window of operation, and delivers 185 amps of power for semi-industrial applications.
Wide output range of 30-185 amps
Welds material from 22 guage up to 3/8 in (9.5 mm) thich in a single pass
Easily adapts to aluminum - simple add optional Spoolmate 185
High-strength, cast aluminum drive system
Industrial-quality braking system for wire spools up to 12 in (305 mm)
Wire sizes: solid or stainless steel, .023 - .035 in (0.6 - 0.9 mm); flux cored, .030 - .045 in (0.8 - 1.2 mm); aluminum, .030 - .035 in (0.8 - 0.9 mm)
Negotiable on price, but in no hurry to get rid of it.
This is a surplus unit in a franchised car repair shop which has been in business for over 13 years and will remain in business.
Will help with delivery. Email to schedule an appointment to see the equipment. Let me know where you're located. Serious inquiries only...we are running a business after all.
