Up Topic Welding Industry / Technical Discussions / PWHT
- - By khodabandeh (**) Date 10-17-2005 04:45
Dear Sir,
With all due respect,according to paragraph 331.1.1.b of ASME B31.3, heat treatment to be used after prodution welding,now my question is: if for some reason welding is done after post weld heat treatment is it necessary to cut the joint and then perform post weld heat treatment or only post weld heat treatment is enough?
Best Regards.
Parent - - By - Date 10-17-2005 13:26
Sir,
I can see why you have a problem with your job. Do you pay any attention to anything in this Forum? Your post on 15 October "Post Weld Heat Treatment" has been answered already. Are you just using this Forum to amuse yourself?
Parent - By khodabandeh (**) Date 10-18-2005 05:05
I am sorry,I repeated same question by mistake.
Best Regards.
