We have used all of the test that you have mentioned, with limited results. The grind spark test takes some time and experience to understand (especially if one is color blind). We use a drill test and have had great success with it. When you drill steel, it makes chips and shavings that are easy to recognize. When you drill cast iron it will make a fine, graphite like dust. You only need to use a 3/16 or 1/4 drill, and only go deep enough to identify the shavings. It works 99% of the time. Most people assume by the look of a fracture surface that the material is cast iron, more often then not it's cast steel. Cast steel still should be pre-heated and welded with some level of care, but cast iron as you know take much care.
