From what I have noticed about jobs detailed by Xsteel:
1)Shop hours run way over the estimate.
2)Fitters spend lots of time trying to figure out what the drawing is trying to show.
3)Drawings are not checked for accuracy. I'm told that the detailer simply checks the input and that this is common practice with Xsteel detailers.
4)Work Points are out off the steel.
5)Skewed end plates have the out to out dimns shown from out at the fartherest most edge of the plates that are on skew rather than at the beam centerline face of the plate.
6) There are no point to point or set back dimns anywhere on any piece detail and you have to rely on the cut length shown in the bill of material.
I can just go on and on about how sorry the drawing presentation is with Xsteel. But in it's defense, the steel goes up without a hitch. How? I have no clue because it leaves the fitter's table with all of us scratching our head hoping it's right because it doesn't give the checker any way to check the dimns.
end of rant
John Wright
