Are there any AWS or industry specifications for determining adequate penetration/fusion? We have a circular steel tube into which is placed a solid plug. Both parts are chamfered to create an external, circumferental, symmetrical weld joint when assembled. The plug has a pilot shoulder that fits inside the tube. When welded (subarc), there will always be part of the plug shoulder that is not fused to the tube by the weld. We have sectioned and etched several joints and we have complete fusion within the initial geometry of the weld joint, but how far beyond this area is fusion required as either a distance or an increase of area of the weld joint area?
